Symfonium 7.2 not working with Navidrome 0.51.0
I deploy Navidrome server via microk8s and after updating to 0.51.0, 0 data are shown in Symfonium after sync.
Previous Navidrome (0.50.2) worked really well.
Upload description: I uploaded the log and its name is ‘sixtyfive’.
BTW, I really love this new log-upload procedure :slight_smile:
 Not provided
 What I did after enabling the debug mode is 1) Delete previously registered server, 2) Re-register the server (Navidrome 0.51.0), 3) It automatically fetch metadata, and 4) Nothing is shown in the home screen.
https://xxx/rest/search3.view?query=%22%22&songOffset=0&songCount=1000&albumOffset=0&albumCount=0&artistOffset=0&artistCount=0&u=REDACTED&t=REDACTED&s=REDACTED&v=1.13.0&c=Symfonium&f=json (9ms, unknown-length body)
2024-01-25 16:15:05.569 Verbose/SubsonicLogger: <-- [560] {"subsonic-response":{"status":"ok","version":"1.16.1","type":"navidrome","serverVersion":"0.51.0 (fd61b29a)","openSubsonic":true,"searchResult3":{}}}
Your servers says that you have no songs, check Navidrome logs
@deluan
So, it’s server-side problem. Thanks for the check!
Can you check if you see any errors in Navidrome’s log? If you see any errors, please open an issue in Navidrome’s GitHub page.
I already uploaded the log: [Bug]: Internal server error on almost all screens after upgrade from 0.50.2 to 0.51.0 · Issue #2806 · navidrome/navidrome · GitHub
