Symfomium ratings & favorites not being set in Navidrome
Hi, I love Symfomium as I recently setup Navidrome and this is the best app by and large.
However, when I rate songs in Symfomium or favorite songs, they aren’t saved in Navidrome. I’m using Symfomium v8.0.0a and Navidrome is 0.51.0.
Any help would be appreciated!
Thanks!
Upload description: ajtatum-2024-02-18a
Recently played doesn’t update as well
You probably have the database issue in 0.51.0 and need to update to 0.51.1
--> [440] GET http://192.168.185.126:4533/rest/setRating.view?id=7400c392c455d5f1652a0097e93fd2a1&rating=3&u=REDACTED&t=REDACTED&s=REDACTED&v=1.13.0&c=Symfonium&f=json
<-- [440] {"subsonic-response":{"status":"ok","version":"1.16.1","type":"navidrome","serverVersion":"0.51.0 (fd61b29a)","openSubsonic":true}}
--> [312] GET http://192.168.185.126:4533/rest/star.view?id=348b75a4f8453ec6f34c83531acb6453&u=REDACTED&t=REDACTED&s=REDACTED&v=1.13.0&c=Symfonium&f=json
<-- [312] {"subsonic-response":{"status":"ok","version":"1.16.1","type":"navidrome","serverVersion":"0.51.0 (fd61b29a)","openSubsonic":true}}
--> [716] GET http://192.168.185.126:4533/rest/unstar.view?id=348b75a4f8453ec6f34c83531acb6453&u=REDACTED&t=REDACTED&s=REDACTED&v=1.13.0&c=Symfonium&f=json
<-- [716] {"subsonic-response":{"status":"ok","version":"1.16.1","type":"navidrome","serverVersion":"0.51.0 (fd61b29a)","openSubsonic":true}}
The proper commands are sent and Navidrome says OK.
Thanks! Looks like it’s all syncing now. Sorry for not responding sooner, forgot to turn on notifications on my phone.
How do I fix this on my end?
I still have this issue and I am on the latest Symfonium (10.0) and Navidrome (0.51.1). Favorites are not getting sync’d and the logs say the same thing from your post
2024-04-19 15:15:43.041 Verbose/SubsonicLogger: --> [142] GET http://IP:PORT/rest/unstar.view?id=5139bef3830aab761661071a8a9bf898&u=REDACTED&t=REDACTED&s=REDACTED&v=1.13.0&c=Symfonium&f=json
2024-04-19 15:15:43.110 Verbose/SubsonicLogger: <-- [142] 200 OK http://IP:PORT/rest/unstar.view?id=5139bef3830aab761661071a8a9bf898&u=REDACTED&t=REDACTED&s=REDACTED&v=1.13.0&c=Symfonium&f=json (69ms, unknown-length body)
2024-04-19 15:15:43.110 Verbose/SubsonicLogger: <-- [142] {"subsonic-response":{"status":"ok","version":"1.16.1","type":"navidrome","serverVersion":"0.51.1 (6d253225)","openSubsonic":true}}
2024-04-19 15:15:38.746 Verbose/SubsonicLogger: --> [801] GET http://IP:PORT/rest/star.view?id=5139bef3830aab761661071a8a9bf898&u=REDACTED&t=REDACTED&s=REDACTED&v=1.13.0&c=Symfonium&f=json
2024-04-19 15:15:38.826 Verbose/SubsonicLogger: <-- [801] 200 OK http://IP:PORT/rest/star.view?id=5139bef3830aab761661071a8a9bf898&u=REDACTED&t=REDACTED&s=REDACTED&v=1.13.0&c=Symfonium&f=json (85ms, unknown-length body)
2024-04-19 15:15:38.826 Verbose/SubsonicLogger: <-- [801] {"subsonic-response":{"status":"ok","version":"1.16.1","type":"navidrome","serverVersion":"0.51.1 (6d253225)","openSubsonic":true}}
When I look in Navidrome, it did not update it. I double-checked which user I used to login to check the favorites sync. I did not apply any custom headers or anything in Symfonium for the Subsonic server, neither did I turn on that toggle to send user/pass in Proxy Authentication. I tried turning on LEGACY authentication, but that didn’t work either. I only see 200 OK’s in the logfile.
PS: Recently Played DOES sync properly, so that’s odd
Check navidrome logs and ask on Navidrome forum.
The commands are sent and Navidrome says OK, there’s nothing more I can do on my side
Disregard my previous comment.
Info for Navidrome users: Navidrome defaults to “album favorites” when you navigate to the Favorites on the main menu. While it is listed under the Albums tree, it’s kind of easy to miss that it’s related to that only, since it’s the only Favorite button on the interface. To see the song favorites, you have to go to Songs and then filter for it (there’s no button for that)
