Syllable lyrics format not supported
I got this track to test this new feature but apparently Symfonium reads the timecodes as normal synced lyrics instead syllable lyrics
Upload description: zyntaxyz syllable
You can see the lyrics source into the lyrics file. I uploaded both files
I tried playing the track with lyrics embedded into file and with the lyrics file only, got same results.
Those are ttml lyrics not lrc ones. Not yet supported but will add support.
