I rated a lot of tracks while offline by having the 5 stars option toggled and going to the now playing track and SLIDING my finger on the rating, which allows to modify it even while offline on android. It does not work when just taping the exact rating, you have to slide across the stars. the rating will then stay there until i sync with navidrome. It’s just discarded after that
debug-20230503_155441.zip (9,4 Mo)
