Support for Animated Cover Art (webp)
As more albums get an animated cover variant (as seen natively on Tidal or from Spotify canvases) I think it’d be awesome if Symfonium could also display those like Navidrome does.
As of right now, the webp file is already being displayed but as a static image.
Having them actually animate only in large views (song playing or album opened) would of course be better to avoid visual noise when there’s a lot of small covers on screen.
This does not solve an existing problem
Prettier album covers where available
Navidrome Web UI: The Navidrome interface already displays animated WebP covers since the format is natively supported by the img tag.
Example from Navidrome:
gif-example-animated-cover
Can you upload some of those to https://upload.symfonium.app ? They are in the tag?
I’m curious. Do you store both a static version and an animated version or only the animated one? Embedded or as Cover.webp for example? And where do you source these? Personally I’d be hesitant to add them as I think many players don’t support them yet and some won’t ever (the dev of MusicBee for example said he won’t add support for them).
I uploaded the examples but I have no idea where the files went
(Including webp and the originally sourced mp4)
@655321 I store the animated variant as a separate cover.webp with a static folder.jpg alongside it and also a static variant embedded in the metadata (for the very compatibility issue you mentioned).
I personally don’t like using WebP due to filesize bloat and terrible compression but it was already supported by navidrome and it’s still better than GIF
I source these either from Tidal, which has official animated covers, or use cropped versions of Spotify canvases. Both being mp4 originally.
In fact, Tidal serves these as mp4 videos as seen on TIDAL
I just started using this awesome app. I really think this feature would make it so much better, as it would add that extra element which no other mobile apps of this type have (besides the subscription services like Apple music, etc)
This would change the game. :thinking: Im already thinking of the custom arts I would make. I’ve actually never heard of Webp im assuming its an image version of webm. Definitely think this would be a very welcome addition. No idea if i could source official ones but id most definitely spend too much time making my own
Not sure if this will be helpful but ive just found that foobar supports this in a bit of a roundabout way.
Essentially this plugin or component can display “images” that are stored in the same path as a Given Track.
So people have taken “Album.mp4” & renamed it to “Album.gif”
the plugin then displays the video on loop (if available) or the standard embeded art. The downside to this is if you have different art on each track the only workaround is to have multiple folders each with video files whose extensions that have been altered.
So A Folder “Album X” & within “Album X” are Folders with the following names
D01 T01
D01 T02
(Etc…just as an example)
In each of those subfolders of “Album X” there’s an mp4 file thats been renamed to “Album X.gif” as well as the Track(s) you want that video to appear on
All the implementations of animated art seem to be outside of the physical files which i assume is bad news as google doesnt seem to like giving access to android devices in that way. I do still hope for some sort of implementation for animated covers in the future but this leaves me with a question
If users were able to figure out how to embed a video or gif as an album art how difficult (if even possible) would it be to support those file types in Symfonium?
Now I’m just spitballing here as a civillian with hopes, dreams 0 insider know-how.
Would it be possible to utilize a similar implementation to the Kodi Style Artist Information Folder added in V12.2.0?
A folder placed in the root of the library with subfolders of albums to match those in the library. Within those folders the user places gifs webp or mp4 files…whataver works really.
Then users can maybe toggle if they prefer to see the animated art just like they have the option to prefer per track art.
Obviously this is very likely a massive oversimplification not to mention the possible hinderances from google but i figured throwing a dumb idea out there may spark a better one or turn out to be not so dumb after all. :man_shrugging:t4:
I just want to bump this as I had the same thought today after implementing a few animated webp files as my covers on Navidrome. Would be an awesome feature.
This feature would be a game changer, hope it can be added at some point.
Would love to have this feature
Apple Music Artwork Finder by Ben Dodson try this go on apple select an artist or an album single that has an animated artwork or animated header
I’d like to have that feature too !
Thanks to this post, I have also added webp animated album art to my navidrome library.
Would love to see this feature come clientside in the future.
Aaaand another one. Id also love this. App just looks to good and is too configurable to NOT have a animated cover option
Now that this is supported:
How do you people create the actual .gif or .webp files? All the linked sources in this thread yield .mp4 files that are not supported.
I’m particularly interested in .webp because I dislike the limited colours of .gifs.
A quick search yielded this guide for encoding .mp4 files as animated .webp.
I think it would be neat if tools or ffmpeg commands that yield good quality .gifs/.webps could be shared by users who have used animated covers so other users who stumble upon this request can get an idea of how to get started.
I’ve made .gifs using ffmpeg and placed them in my folder structure with the proper tags.
It seems that Navidrome won’t resize gifs, so they only play in the full resolution (when you click on the album art, it renders the animation). I’m assuming that this server-side limitation is why these gifs also don’t work in Synfonium (gifs are detected, but only see the first frame of the animation).
Will try the webp method, I had converted some mp4 files to webp previously and they seemed to work well, just need to get them looping :slightly_smiling_face:
Since 14.1.0 version introduced support for animated cover art, could someone provide a quick guide on how to do it? I’m trying different methods, converting mp4 to gif or webp, and nothing work. Also wondering if it works only with local files or I can use it with Jellyfin as media provider, It would be great to see some sort of official guide which one is supported, and which is not.
EDIT:
  1. ffmpeg -i video.mp4 -vf "fps=15,scale=480:-1:flags=lanczos" -loop 0 output.webp
  2. Use kid3 to remove previous cover and just selected the converted cover, doesn’t need to change any setting, program showing mime type image/jpeg is fine.
  3. Importing file locally works. Jellyfin - doesn’t, probably because of their limitations. One thing you can do is import song to Jellyfin then press three dots in symfonium and select change local thumbnail. That way the song is on Jellyfin and the cover sits on your device.
Is there any other workaround however for using it with Jellyfin? Some plugin or anything?
