Superscript text format for custom strings
Support the ability to format text as superscript (sets slightly above the normal text and in a smaller size).
In my use case (although there might be other uses) I want to display simple/short/tiny information about tracks, like play count as a superscript of the song title in the now playing screen.
One more format type for custom strings and ability to display small/little details that don’t need too much attention.
Hi, thanks for implementing this. May I ask what is the syntax for using this format? I could not find the info in the documentation.
As it will be implemented in the next beta im sure the doc will be available when it arrives
##vsdf dsfdsf dsfsdfsdfds fsdvvv##
