Suggestions for Chinese search function
#feature-requests
When searching Simplified Chinese, you can search the corresponding Traditional Chinese at the same time, and return the contents of Simplified Chinese and Traditional Chinese
case:
邮(Simplified Chinese) = 郵(Traditional Chinese)
seacrh(邮) = seacrh(邮)+seacrh(郵)
seacrh(郵) = seacrh(邮)+seacrh(郵)
Sorry no idea how to do that and can’t find anything from a quick search.
Do you have some technical information link about how that conversion can be done?
See if this will help you
link: houbb/opencc4j: :cn:Open Chinese Convert is an opensource project for conversion between Traditional Chinese and Simplified Chinese.(java 中文繁简体转换) (github.com)
Thanks, so this require very large dictionaries :frowning:
I’ll keep this in mind if I can find a way to have those dynamically loaded but I can’t add such large library by default as Chinese users can’t even purchase the application for now due to Google not supporting it there.
Thanks, Looking forward to that day, I will continue to look for it.
