Hi Tolriq,
Hope you’re doing well.
I use a Carlinkit Android device in my car. It tricks my car into thinking an Apple CarPlay device is connected, but it’s actually a full Android OS that shows up on my car screen, like a phone with Google Play Store, etc. No limitations such as keyboard restrictions. It’s a full Android OS.
The problem is, Symfonium starts up so quickly that sometimes the mobile data connection isn’t ready yet. When this happens, Symfonium shows an error saying no license could be found. This wouldn’t be annoying if it disappeared once the mobile data connects, but it doesn’t. I have to manually force close the app and open it again for it to work. This is a bit tedious to do every time on a car screen. Could you check for a connection every 2 or 3 seconds, or when one becomes available? It used to work fine, but this started happening after a few updates ago and has become a bit tedious.
Thanks in advance!
Upload description: Clicked share logs with support in the app shared under username Meap
Start the app with no internet connection, then start the internet connection afterwards. Symfonium will fail to re-check for a license and stay on the screen telling you no license was found until you force close and restart the app.
