In the Now Playing screen, the string icons (e.g., the heart and playlist icons) next to the song title are not fully aligned to the right edge of the container. Instead, they are aligned only relative to the length of the text string, causing inconsistent spacing and alignment — especially noticeable for short titles.
Upload description: xcuze99_stringicons
Expected Behavior: The icons should be aligned to the far right edge of the container, regardless of the string length maintaining consistent UI layout across songs with varying title lengths.
Notably, some users have the icons displaying correctly (2nd image), aligned flush to the right edge. I don’t know if it’s only me or if I missed some settings.
Step-1 : Enable String Icons
Step-2 : Select String Icon Position to Right
Any provider
