Static-y crackling sound occurs randomly during playback
After playing tracks for a while (offline cached from Jellyfin) with DSP and autoeq enabled, the audio becomes very distorted, static-y, and crackles a ton. Turning DSP off and on again temporarily fixes the issue.
Issue occured at the very end of logging. I also turned off and on DSP to fix the issue before ending logging.
Device - Pixel 8 Pro
DAC - JCally JM6 Pro
Headphones - Kiwi Ears Cadenza
Upload description: aestellic
Unfortunately as the DSP as the DSP page says those are library provided by the OS and there’s not much I can do when they bug. With that said Google usually quickly fixes those unlike other OEMs.
Oh shoot, forgot to mention I’m on GrapheneOS! Thanks for the heads up about it being OS dependent though.
