Spotie (in progress*)
Very cool theme. How do you place the home icons on the playback screen?
I’m not sure I follow, can you describe what do you mean?
If you’re talking about the navigation bar, then it appears in the the now playing screen too once you chose the “now playing" navigation entry.
How did you get the heart symbol on the now playing screen to that size? Mine is much smaller and I dont know how to increase the size?
Yep I feel stupid now. Thanks for pointing out the obvious to me :smiley:
You’re welcome. Good luck with your stuff.
It looks great!
I hope you can share it soon.
Yeah, sure. I just lost all my data and saved designs, but it’s fine now, I’m working on this one too, maybe I’ll finish it.
Great! This one looks even better, I’ll keep an eye out.
Can you share the details of the various blur & transparency settings for the pages youve shared that leverage those settings? I really like what youve done to capture depth without it looking like a bottomless pit lol
Can you share the config file for this?
Sure, I just need some time, I don’t really think it’s worth it, it feels unfinished and I don’t really know what to add there, maybe I’ll rework it completely and make it look as something else instead, also I’ll probably release it with the whole theme, it’s almost done anyway.
Sure, soon I’ll release it and you can see it yourself and adjust for yourself, it would be easier than me explaining every single detail.
Album page concept.
I like how it looks. You should upload it as is; I know several people like it.
Some screenshots of the current home page.
New possible Now Playing design
