Specific album not showing on albums section; can still see it on Home
I have downloaded a series of albums that all have a title that goes from 2003 to 2016
all the albums are showing on the album section except for the one named 2016
i checked the metadata and it has information on the same fields as the other ones, with the same artist album, however it’s just not showing on the album section
i even added its folder as one of the media providers but nothing changed.
What must i change for it to finally show on the albums section aswell?
Upload description: Album_not_showing_on_albums_section
It’s weird because it just won’t show up there with all the other ones with the exact same kind of information
below are the images showing the album displayed on the home section, then it not being on the album section following the pattern (even searching for it there won’t give any results)
It also shows under the artist’s albums, it’s only the specific album secton
I went to media provider, changed the “split albums by” option for several categories multiple times and tried multiple combinations (disabled musicbrainz ) and the album still wouldn’t show up on albums section
It’s probably a compilation. Use the all albums node if you want them merged.
Just replying to say it really was being recognized as a compilation.
Went to settings → interface → Navigation and media start and changed the “main navigation entries” to also display library/all albums. it’s now showing although it’s on the “all albums” section (since it’s marked as a compilation in its metadata)
