A sortmode feature where you can reorder the stations at any time by moving each one up or down individually.
I have over 200 radio stations that I go between. I switched to Symfonium from an old custom url app specifically because it works perfectly with the media widgets I now use. However, I order my list of stations by genre. If I want to add a station later I can’t just insert it where it needs to go on the list. My old app has a sortmode feature and would love to see it here if possible.
I think anyone with a large amount of stations or anyone that wants to customize their list in a specific way would appreciate this feature.
the app CustomRadioPlayer has this and it works great.
I have included screenshots of the CustomRadioPlayer feature. You can move each station up or down by holding and moving the hamburger on the left side of each station entry.
