Hello, thanks for the good work on the app.
I’m trying to use the sort by filename feature, but I can’t seem to get consistent results.
I’m using Navidrome 0.60 as a media provider if that’s relevant.
The order is incorrect even when file names are numbered (01 - Song, 02 - Song). A few tracks will end up a the end of the list (for ex 04 and 08).
When checking details on the songs within Symfonium, the filenames feature the correct number (though the file structure is different than the source folder, not sure if that’s Navidrome renaming/reordering files), so if Symfonium uses that, it should sort properly in any case.
I haven’t be able to determine why some files sort wrong and other are sorted properly. I can provide the files upon request.
Navidrome
- Sort by filename
- Check wrong album order
debug.log
