I’ve recently noticed when playing tracks via UPnP (SONOS) anything with 🅸 (Negative Squared I AKA: -U+1F178) is being automatically skipped & I do not recall this being an issue before.
- Open the “Play On” menu
- Select SONOS Speaker
- Begin Playback
I originally though this was an issue with M4A tracks but after playing a few I noticed it was specifically my instrumentals only.
I’ve uploaded my “test” file with the same description: SONOS - I
I use the 🅸 to quickly denote instrumental versions of tracks as it’s easy to spot in the UI & much shorter than “(Instrumental)” in my titles. I wish it were a supported denotation like the negative squared characters used to indicate Clean or Explicit versions of tracks but I’m an oddball so this is my Jerry=rigged version of that. Again I don’t recall this being an issue in previous versions. The only things I couldn’t get to play over SONOS before were OPUS tracks.
SONOS - I
