Sonos Play:1 UPnP playback not playing/skipping tracks
Hi, I’m trying to stream to my Play:1s on my home network via Sonos UPnP - I can see all 3 of them on the cast selection screen, and the app acts as if they have each connected successfully (I am trying one at a time). When I then go to play, nothing plays through the speakers, though the app shows playback for a couple of seconds before moving to the next track (and sometimes 3 or 4 tracks) before stopping. I’ve tried toggling the gapless support and alternative flags on each of the devices, but with no luck. I was wondering if the logs showed anything that I am doing wrong?
I using Navidrome 0.55.2 (a057a680) via Docker, and Symfonium 12.3.5a (127414).
Upload description: XRD7 logs
For me, I connect to any Sonos Play:1 via cast menu and then play a track.
You are transcoding to opus and Sonos does not support that.
So I just need to turn off transcoding within Symfonium? I didn’t think I had it switched on - thanks for the speedy response as ever!
EDIT: Settings > Playback > Decoding and Transcoding, and in there I had Mobile/Wifi maximum bitrate set to 320 kbps instead of ‘original’ - immediately fixed it! Thanks again!
