Sonic-analysis-based smart queue does not work on Android Auto (Radio Mix)
Hey, seems like triggering Radio Mix while using Sonic-analysis-based smart queue on Android Auto, does not work as expected - using Navidrome with AudioMuse-AI.
Navidrome
  1. Make sure you have a properly configured Symfonium-Navidrome-AudioMuse-AI setup.
  2. Make sure you have configured one of the Media Session buttons as “Radio Mix”.
  3. Start Android Auto and pick any song. Start playing it.
  4. Tap on “Radio Mix” button on Android Auto interface.
  5. Check the playlist queue → new songs are added to the playlist queue, but none of them are acutally coming from “Sonic-analysis-based” feature. Seems like they are just “regular” radio mix collected songs.
Important: repeating the same scenario but using the app on the phone, returns the proper list of queued songs (sonic-analysis-based one).
Important 2: as a double confirmation of proper queuing songs on phone app - I’ve retested the same path on Feishin (desktop Navidrome client) using the same song (“Nienawiść” by Myslovitz as you can see in logs) → queued list is the same as the one returned on the phone app scenario.
cookie_phoneapp, cookie_androidauto
Hey @Tolriq - is there a chance to have it fixed? Not asking for ETA. :slight_smile:
@Tolriq Seems like on 15.1.0 bug is gone. Thank you!
