Songs skip after few seconds
Hi, I’ve got few songs that are being skipped after a few seconds of playback. FLAC and MP3 both. I’ve generated debug of each. Existing forum topics pointed to files being corrupted, but I’ve tested the files with flac and mp3checker and they both seem to be fine, and other clients such as Feishin have no problems with them.
Navidrome
  1. Select song to play
  2. 4-5 seconds play and then they skip
Logfile for 09:46 AM on 12th of April is the relevant part
upload those files to https://upload.symfonium.app
Done! I’ve trimmed the logfile to the relevant section (had previous debugs).
the music files … :wink:
Whoops… done :slight_smile: Sorry.
Quick update: I’ve just tested them using a different network (not local WiFi but remotely VPN+wired) and it works… so this means it must be a network related issue, but very strange… anyway hopefully I didn’t send you into a crazy bug chase :sweat_smile:
Maybe the playback cache is corrupted you can clear it. But the logs did not show the actual issue so this is strange yes.
