Song Mix Settings / Shuffle all Songs on Android Auto
Firstly, this app is fantastic - one of the best music player apps I’ve every used!
I was wondering if it would be possible to introduce a setting to change the Song Mix feature to simply shuffle all songs?
Alternatively, would it be possible to expose “All Songs” with a shuffle in Android Auto?
I’m personally not a big fan of algorithmic track selection as my music library is already curated and I’d preffer just a simple shuffle. Unfortunately this is not possible to initiate while driving.
Thank for all your work!
Fill the mandatory template …
What’s the issue with the mix it ensure no repetition and shuffle could lead to the same result.
Furthermore you can / should use voice command and just say play some music to have a full Shuffle.
I thought my request was quite polite, and this isn’t Github.
Don’t worry about it then, I’ll just go somewhere else.
Go back to sniffing your own farts :peach: :dash:
Well there’s a mandatory template and messages everywhere about the template being mandatory.
So when you go somewhere and ignore the simple rules, then act like you do when remembered that you ignored the rules, neither the rules nor the messenger are the problem.
Insane how respect is lost and how people feels entitled…
