When in my car (using Pixel 7a on Android Auto, VW ID3) I chose option Song mix (see “Reveillons-Nous” entry, around 17:56, in logs), queue starts playing. After I’m at my destination I leave car. After I enter car again, queue automatically resumes playing, but it always forgets where I was in queue and starts from the top again (around 20:20 in logs).
I connect with Navidrome on ultracc.
After stopping and resuming several times the queue is usually completely lost after a while. Don’t have logs of this situation yet.
Tried uploading again, but I have no idea if this works or not. Or how I add description so you could match uploaded file to this topic?
I just do this and press Submit:
When I click on top left logo of page I get redirected to Symfonium: Secure file sharing and there it seems as if I’m not logged in? When I try to do so with same credentials that I use here, it says “login failed”.
Ok so this is the same as the issue from widgets, the app is killed in the background and then AA sends the play commands that race with the queue restoration.
