Some songs not playing on UPnP
Some of the songs freeze when played via UPnP but when that is disconnected, they start playing just fine. They also play fine with another app (Bubble UPnP).
I have toggled the UPnP settig and playback setting options without much luck. I’m looking for help to keep all my music with one app.
Playing music via UPnP to Yamaha receiver. Some songs play great, other are stuck and don’t play until the UPnP option is disabled. Logs are uploaded.
meemy
I can’t guess things you are supposed to tell me the one that does not work :wink:
I guess it’s the ogg files that your renderer does not support ?
I am not very tech savy so a bit difficult to anticipate what you’d like to know from ne or expect in the logs.
seems like you’re correct though. Ogg files but some flac as well.
