Snooze songs for a certain time period
Basically a button that prevents a song from being played for a specified amount of time. A new smart filter option can be added to list all the songs that have been snoozed (along with how long before they are ‘re-enabled’). This way, when a user would like to ‘re-enable’ a song before the snooze period has ended, they can do so.
When a playlist containing this song is started, the song should ideally be excluded from the queue too, to respect this snoozing period.
Since we all know that Symfonium is better than Spotify, an extra addition could be a popup dialog when pressing the snooze button that asks how long to snooze a song (for example a text box in which you enter a number of days/weeks).
Songs that keep repeating due to the continuous playback (or just a lot of playlists that contain those songs) can sometimes be bothering, causing users to not want it to hear for a little while.
Giving songs a 1 star rating is a possibility to achieve this too, although you cannot specify a time period which causes the need to manually remove the 1 star rating (or just forgetting about the song). On top of that, it will be mixed with other (so to speak) real 1 star ratings making it quite difficult to know which songs you didn’t want to hear for a while and which are just bad songs.
All in all, it is something that could be achieved through various methods, but the possibility to click just one button and the fact that the songs will be automatically ‘re-enabled’ makes this for a non-existing but still useful feature.
This, although Spotify is more restricting in the sense that the snooze period is fixed: https://www.techradar.com/audio/audio-streaming/spotifys-new-snooze-button-will-let-you-blacklist-unwanted-songs-for-a-month-and-i-wish-it-had-existed-earlier
There’s already the exclude from mix for that need. I don’t see the value and needed complexity of adding a timing to that sorry.
I get why you say that, but the point of the timing is to not forget that you excluded songs from mixes because the only way to see those songs is by deliberately filtering all your music for songs that you excluded, which a lot of users probably just forget about.
And even more users won’t exclude tracks at all, the cost to maintain that thing is just not worth it.
Alright, it was just an idea :slightly_smiling_face:
Nobody’s forcing you :wink:
I like the idea. :+1:
