Smooth background color transition on now playing screen
Currently when using any background style (like Blur etc.) for now playing screen, when I change the song, the background need to be adapt to the album art of the next song, but currently that adapting colors thing is abrupt, as in currently if I press next song button the song changes but the background remains same for half a second and then abruptly changes after half a second, which makes it seem like the background is lagging behind the album art.
(Not comparing symfonium and this app, just describing with the help of a video) So a much more smoother shift in background colors is required when changing the song. Like this -
In the ending part of the video I have tried to slowly swipe on the album art so that you can actually see how the colour transition is happening.
Smoother color transition while changing songs
Poweramp (link attached in description)
The transition is delayed on purpose but colors are already animated unless you enabled the option to not animate color changes :slight_smile:
Is there any particular reason why the transition is delayed? Doesn’t it feels off to you like its lagging behind? Also is it possible to add an option to select the delay in transition so that can remove that delay?
Also can you guide me to the animate colours option that you are talking about, so that I can check
Interface/ Theme bla bla 20.char
So, is it a no from your side for adding an option to select the delay in transition so that can remove that delay?
Hey @Tolriq waiting for a reply here😊
