Upon switching networks, playback stops and a loading animation appears around the play button.
The app begins skipping tracks repeatedly as it fails to reconnect to the SMB source.
Crucially: Other apps (file browsers/streaming) continue to function perfectly over the SMB/Tailscale link during this same window.
Current Workaround:
Closing the app from the “Recent Apps” switcher does not resolve the issue.
Only a System Force Stop and relaunch restores the connection immediately.
Request:
It appears the SMB implementation may be holding onto stale network handles during an interface change. Could you look into making the SMB reconnection logic more robust to prevent these hangs?
Upload description: NetworkSwitchSMBFailure
This does not happen everytime. Sometimes, I am able to leave WIFI and keep streaming nearly seamlessly.
-Tailscale working
-Other apps working
-Leave apartment WIFI and connect to Mobile data
-Tailscale still working
-Other apps still working and files accessible
-Symfomium stops playing
-Force close in system app settings
-Repopen
Thank you so much for the fast reply. I can definitely pull all of the logs for you if the issue persists but can we leave this ticket active or at least in a dormant state as I see if the solution I attempted in the following paragraph is going to work long term?
I’m able to switch from Wi-Fi to mobile back and forth without the issue after using the following commands on my Windows 11 Pro acting as file server:
This fixed it been network switching very smoothly during playback for a week. Ran it on my Windows 11 pro file server hosting the shares via powershell
