SMB not working via ddns hostname
I have had smb working for while and recently there was an issue on the nas / router side which is fixed now. I can access the nas via ddns entry from iPhone media apps but is not working from symfonium. When I add a new media share via local ip address i am able to add the media provider but not using the public ip address or ddns name. I did upload the debugs
Upload description: elderbank
Samba
Well seems you did not fix all :slight_smile:
Try to add the provider directly with the external IP to see the actual errors, but this is a network issue.
