Smart Playlists Inheriting Global Filters
I’d like the ability to have smart playlists adhere to the currently enabled / disabled Global (source) filters.
I have smart playlists which feature multiple versions of tracks (Clean vs Explicit & M4A vs OPUS). I’m often editing the playlists provider / library to fit the needs of the day or situation & it would be nice to quickly toggle smart playlists based on the Global filters selected, then I would not need to edit the global filters and edit the smart playlists individually.
Users with playlists that feature tracks from various sources or folders can more easily tapper smart playlists.
Screenshot 1 Shows my current folders.
In essence I’d like to be able to toggle in the source filter [E] (Explicit Versions) & My smart playlists will show any tracks on that playlist that are in the folder [E]
If I toggle folder [E] off I’d like for those same tracks to no longer show.
For anyone curious as to why I carry multiple versions of the same songs
  1. [E] & [C] • I play music at events from time to time & these may be CLEAN only sessions.
  2. M4A & OPUS • SONOS doesn’t like OPUS but OPUS is better quality.
    I haven’t bitten the bullet to just keep on over the other because things may change…
  3. WAV & FLAC • A few albums I’ve got are very high Quality WAV but WAV doesn’t always play nice so we have FLAC versions of those for compatibility.
