Would it be possible to have a “played percentage” filter, so if i played more than 50% of the song, it would be added to a smart playlist, and similarly, if i play less than 10% it would be added to another.
I am lazy, so sorting songs i rately listen to and often listen to is not something i do much, and I would also like a filter on my “cache” playlist, so if i play less than 50% it does not get added.
A new filter option i am sure many others will find a use for, maybe similarly to my own needs/wants.
I have yet to find another app that can do this, then again, i rend to try one app at a time, and if it works i remove the other candidates.
Not sure if more details are needed, but if you need any details, feel free to ask.
