First of all, thanks for the great app! I had a few ideas that might help improve the experience and just wanted to share them.
Show buffer on progress bar (waveform and if possible basic).
Add an “Export to Downloads folder” toggle in settings, so when I click Download, it either adds to the permanent cache or exports to the Downloads folder based on the setting which makes downloading music one tap instead of two.
Recent Playlists on the home page without needing to add them to favorites.
Make playlists created in Symfonium sync to the server by default. One of my user reinstalled the app and lost the playlist he created in Symfonium.
Auto-import playlists after adding a media provider.
Add a blur background from the Now Playing screen to the Lyrics screen to make the transition look more seamless and polished.
Remove Skip all silences from More actions for users who only have music — or even better, add an option to customize what appears in More actions, like hiding Skip all silences, Web search, etc. This would reduce the size of the list and make it easier to access the actions that are actually used.
Makes using Symfonium simpler and more convenient.
Makes common actions faster, the interface cleaner, and the overall experience more intuitive.
