Slight Distortion between Gapless tracks
Beta
You said this was a separate issue and that you’ve had no logs to work with, so I’ll just throw this in here for you to look at.
It’s just a small distortion. A short warping sound. But it is enough that I can clearly spot the track transition.
Tracks will be uploaded shortly. I just took a song in ffmpeg and made two outputs from it while copying audio. Can post the exact commands later but it was something like…
ffmpeg -i source.opus -ss 1:35 -acopy output1.opus
ffmpeg -i source.opus -t 1:35 -acopy output2.opus
…to copy the audio up to 1:35 in output1 and then start at 1:35 and copy the rest in output2. (No reason for 1:35, it was a random number.)
Play two tracks which are gapless. Listen for transition between tracks.
Can skip towards the end or listen in full. Seemed to do the same thing either way.
Celorien_Gapless
Tracks uploaded as Celorien_GaplessTracks
You can’t split opus like that and be gapless :wink:
Now I’ve revealed myself as a big dummy lmao
