Skips every other song when casting to Denon AVR
Casting to Denon AVR causes skipping. The first few songs play just fine, but it will start to skip every other song. When it starts it will skip exactly every other song. The song will skip after playing for about 5-10 seconds without issues, skip to next song and it will play that one in its entirety, play another song for 5-10 seconds, skip, play the following song in its entirety, 5-10 seconds of next song and skip, on and on. If I go back to a song that skipped, it will play all the way through but then continues the skipping on following songs.
Issue has been frustrating me for many months now to the point of trying to find another app for casting from navidrome to my AVR at home. But my main use of Symfonium of using in the car with Android Auto works flawlessly.
The above issue does not seem to happen when not shuffling.
Navidrome
  1. Click casting button
  2. Select AVR from list
  3. Go to playlist
  4. Shuffle playlist
Initially thought it was only happening during shuffling playlists. But also happens when selecting a track from anywhere else, really anytime with or without shuffling.
Samsung S24 Ultra - app version 15.1.0 (127812)
Denon AVR-S970H
Casting settings for AVR:
Proxy: no
Prefer offline cached version: no
Stop casting on stop: yes
UPnP renderer capabilities: yes
UPnP gapless support: yes
UPnP stop casting on external changes: no
UPnP alternative flags: yes
atomunder
Please disable UPnP: Gapless support for the Denon, disconnect and reconnect casting, then try the same queue. Let me know whether it still skips.
Your logs show the receiver reporting that playback has stopped shortly after a track change, which makes Symfonium advance. I’d like to check whether its gapless handling is involved.
If it still skips with gapless disabled, please capture debug logs from connecting to the Denon through the first skip. Enable debug mode before starting, then disable it and upload the logs promptly. Reply with the upload description and the time the skip occurred so I can find them.
I will do some more testing to make sure but that seemed to have fixed my issue. Thank you!
