Skipping Before End Of Track
When I am listening to something some tracks will randomly skip the end. It might be just 10 or 20 seconds for a song and as far as I can tell it is just random. When it is a longer track (20-30min) it skips more at the end. When it does this I can go back to the track and scrub to the part that was missed and it will play fine. I have more media providers than OneDrive but that is the only one I can be sure it happened on.
Upload description: Skips the end of track.
One Drive
Are you sure it happened in those logs ? Do you have the name of the track when it happened or the precise time ?
It should be in those logs. The song was “Drummer Boy”. I don’t have the precise time, but I could find the approximate time if you wanted.
Yes I’d need log with precise timing as I can’t see anything but a buffering at some point.
Ok, I understand. The time was approximately 4:50 if that can still help. I can try to get more logs, but I’m not sure how to do it differently.
I haven’t been having the problem recently, so maybe it’s fixed. I’m not debugging for that anymore.
