Single songs shown as separate albums
So, I’m using Emby server, and that works great. But I have a folder with mixed music, various artists and songs, some artists only one or two songs. So, I created a playlist in Emby with those songs. The problem is, Symphonium recognizes each song as a separate album. How to prevent that? Can I exclude that folder from syncing/scanning?
Upload description: No log needed
Emby
Wrong as written a lot. I can’t know what Emby sends without those logs …
Symfonium displays what Emby sends so if it’s a different library you can exclude in the provider page settings or filter via the global filter.
Else fix Emby side of the data.
It’s not a different library. It’s a folder inside my main, the only, music library. There are no error or something in the log. I just wanted to know why Symphonium shows each single song as an album. If I have 10 different songs, bu different artists, in a folder, like a compilation, Symphonium will show it as 10 separate albums.
Again Symfonium displays what Emby sends.
Since you decided that the logs are not necessary despite them being necessary I can’t see what Emby sends to show you.
OK, ok, not a problem. :slight_smile: I have uploaded the log, the name is Nabukodonosor.
And what are the albums names ?
Have you checked Emby album list to see if they are there too ?
They are not there as albums, but as a folder with songs:
And in the app, the first row for example, are 3 songs presented as 3 separated albums:
As you can see they are returned by Emby as albums …
And if you check the actual album list in Emby it’s probably the case too
As explained in each answers: Symfonium displays the data that Emby sends it does not access the tags or the folder structure or anything.
      "Name": "Pump",
      "ServerId": "7837e5d4b3bb4bba83dd925f48daf73b",
      "Id": "20039",
      "DateCreated": "2024-12-27T17:43:07.0000000Z",
      "SortName": "Pump",
      "Genres": [
        "Pop"
      "RunTimeTicks": 3270266670,
      "ProductionYear": 1990,
      "IsFolder": true,
      "Type": "MusicAlbum",
      "GenreItems": [
          "Name": "Pop",
          "Id": 979
      "TagItems": [],
      "ParentLogoItemId": "18786",
      "ParentBackdropItemId": "18786",
      "ParentBackdropImageTags": [
        "efb96f0626c93e1be21caa76438d8a79"
      "UserData": {
        "PlaybackPositionTicks": 0,
        "PlayCount": 0,
        "IsFavorite": false,
        "Played": false
      "Artists": [
        "Aerosmith"
      "ArtistItems": [
          "Name": "Aerosmith",
          "Id": "18786"
      "Composers": [],
      "AlbumArtist": "Aerosmith",
      "AlbumArtists": [
          "Id": "18786"
      "ImageTags": {},
      "BackdropImageTags": [],
      "ParentLogoImageTag": "08ae1d30cabcb61ea72addda8077607f",
      "PrimaryImageItemId": "19589",
      "PrimaryImageTag": "18222faf55ee5c37cc656869ce7f2e00"
      "Id": "20041",
      "DateCreated": "2024-12-27T17:42:07.0000000Z",
      "SortName": "Aerosmith",
      "Genres": [
        "Hard Rock"
      "RunTimeTicks": 2667600000,
      "ProductionYear": 1980,
      "IsFolder": true,
      "GenreItems": [
          "Name": "Hard Rock",
          "Id": 881
      "TagItems": [],
      "UserData": {
        "PlayCount": 0,
        "Played": false
      "Artists": [
        "Aerosmith"
      "ArtistItems": [
          "Id": "18786"
      "Composers": [],
      "AlbumArtists": [
          "Id": "18786"
      "ImageTags": {},
      "PrimaryImageItemId": "19602",
      "PrimaryImageTag": "0a602d70f0106c52ca60d46b49be6ad2"
OMG you’re right! I’ve just found on their forum that in order to avoid this I have to tag every song with the same album and album artist, for example ‘My collection’. That way they will all be one single album, but in Symphonium I will loose the Album information. Terrible solution.
