When under an artist would there be a way to add a button or option to bring up a list or new view that only shows similar artists to the one you were currently looking at? Or even better make it part of the artists page at the bottom under albums and top tracks labeled “Similar artists” and you can scroll through them like you can the albums above?
The concept of Similar artist is complex and requires data that nearly no media provider exposes. Since Symfonium is an offline first application this is not really possible to implement.
If you only says they are similar by genre then you can click the genre at the bottom of the artist detail view.
Thanks for replying! So you say there is a genre list for the artist? I just looked up and down the artist page including the drop down menu under the artist picture but do not see anything that would show what you stated. You are right, seeing a list of artists with similar genre would be perfect I just don’t think I am seeing this option at all?
It depends on your media provider and the data it provide, but yes when on an artist detail page there’s the list of genre clickable in the about part.
I am currently using Navidrome (subsonic) for media. I do have proper tags but I do not see much info on the artists page just albums and top tracks. Thanks for the info.
Huge plus 1 vote for me on this if it’s possible. Probably one of my most used features of DSub because it’s so easy to listen to an album and then pull up similar artists afterwards. I think DSub pulls from LastFM which should use MBID’s.
I think the landscape has changed quite a bit since this feature was originally discussed.
Back in 2022 the main blocker seemed to be that there wasn’t really a media provider exposing artist similarity in a usable way, which made perfect sense at the time.
I’ve been doing some investigation after integrating AudioMuse-AI (AMA) into my Navidrome/Symfonium setup, and I spoke to the AMA developer about this. AMA already computes artist similarity during its analysis and exposes it through an API (including similar artists and a representative song), and the Navidrome web frontend is already using that API.
So rather than Symfonium having to invent or source “similar artists” itself, this could potentially become another provider capability, much like other OpenSubsonic enhancements.
From a UX point of view, I think this would fit very naturally at the bottom of the Artist page. The page already encourages browsing through an artist’s biography, genres and albums. A “Similar Artists” section at the end would simply let users continue exploring their own library.
For users without a provider exposing similar artists, nothing would change. For users with AMA (and potentially other providers in the future), it would become another browse path through the collection rather than a cloud recommendation feature.
It feels like this has gone from “where would the data come from?” to “there is now a provider that already has the data.”
Would that make this feature worth revisiting if/when the corresponding OpenSubsonic extension becomes available?
I occasionally check-in with Symfonium to see if this has been implemented yet, so it’s nice to see that the discussion is restarted here because it’s a huge gap in the app’s functionality.
And I see that support for the OpenSubsonic’s sonicSimilarity function has been added in v15.0.1 so I really hope that we’ll see Similar Artists added to Symfonium soon too.
