Side Swiping between 'Main Navigation Entries'
The ability to side swipe on the currently open main menu / chosen navigation rather than pressing the icons at the bottom of the screen
Helps with navigating the app better accross the entire screen, rather than the current available icons
Ease of use for the app in general, may also help those with limited movement / visual impairment to better navigate menus.
Pretty much the way blackplayer switches between menus, works really well and nice to use.
Duplicate and this is an old anti pattern incompatible with many of the features of Symfonium.
So sorry but won’t be added.
