Shuffle songs directly from the Songs library
Currently, there is no way to shuffle your songs directly from the Songs library. Instead, you have to create a Smart Playlist of all your songs and shuffle that. This seems unnecessarily convoluted, and also inconvenient if the playlist doesn’t auto-update when new songs are added to your library (I haven’t checked this though)
The ability to directly shuffle songs, which is clearer for users to do as opposed to having to create a Smart Playlist which isn’t immediately obvious
Envisage the same list of buttons at the top of the Songs library as is at the top of the Smart Playlist, one of these buttons being a shuffle button
You mean like the button that is already there ?
You probably have disable the buttons in settings…
Ah, so I did! My apologies, I didn’t realise I had it disabled! Please delete this thread
