Several songs skipped, ui unresponsive
Here’s what happened from a user perspective. I started my car, phone begins connecting while in driveway. I drive off, leave wifi range. Symfonium attempts to beging playback, but gives “no playable URL” error for several songs. While is is aggressively and repeatedly skipping to the next song, playback cannot be stopped. The play icon button has a busy throbber animation.
The logs indicate “no playable URL” . After several skipped songs (19 instance of “Skipping to next” in log) symfonium is able to access plex again and playback resumes.
I do have a local ad-blocking vpn active on my phone, but since it eventually starts working, that is probably not relevant.
Even if the underlying issue is poor network connectivity, I should be able to stop the continuous skipping behavior without killing the app.
Upload description: flax 11_10_2024
I do have an adblocking vpn on my phone, but as playback eventually resumes, that is probably not relevant.
Uncertain how much is necessary:
Connect phone to car bluetooth while in wifi range, begin playback
leave wifi range
songs begin aggressively skipping to next, playback attempt cannot be stopped.
playback eventually succeeds.
Plex
Duplicate :wink:
Should be fixed in beta and you can always stop by long pressing the play button.
apologies. I searched but did not find anything under “plex” or “skipping”
