Notes:
- Requires Symfonium 8.0.0 at least.
Renderer settings
Symfonium allows configuration that are specific to each renderer, in the cast dialog just press the configure button.
Volume steps
Volume change applied by each button press (Now playing buttons or hardware buttons when casting)
Proxy via Symfonium
Use Symfonium as a proxy when casting to the provider to workaround connection or certificate issues. Will use a lot more battery!
UPnP gapless support
Some devices may incorrectly implement support for gapless, report to support with logs and disable this setting.
UPnP alternative flags
Some devices may require different flags to accept playback, this setting switches between two modes.
Note: The available settings will depend on the renderer type, as upnp settings does not applies to Chromecast for example.
