Notes:
Equalizer - DSP
Open the equalizer and DSP configuration page. See Advanced Equalizer / AutoEQ
Save Now Playing state
Save the current playback state and queue to always be able to resume current queue even after an app kill or phone reboot.
Multiple queues
Enable support for multiple media queues. See Multiple media queues
Personal mixes size
The number of items to queue when starting mixes.
Min. play percentage before marking as played
The minimum playback percentage needed before Symfonium mark a media as played.
Min. play time before saving resume point
The minimum playback duration needed before Symfonium save a resume point. Set to to never to disable the resume functionality.
Remember last renderer
Enable this option to try to reconnect to the last selected player on application start.
Circular queue navigation
When activated, the previous button while on the first track moves to the last track, and the next button while on the last track loops back to the first.
Retain player state
By default when you start a new playback the shuffle and repeat mode are reset. Enable this option to keep their previous value.
Pitch control
Enable pitch control in the playback speed panel. You can disable this option to simplify the playback speed screen if you never use the option.
