Notes:
Cellular maximum bitrate
If your server support it, limit the media bitrate when connected to cellular network (Transcoding)
Force instant transcoding
When transcoding for cellular and loosing wifi, instantly restart the playback in transcoding mode to reduce network data usage.
Wifi maximum bitrate
If your server support it, limit the media bitrate when connected to wifi network (Transcoding)
Prefer internal decoder
Prefer the usage of Symfonium internal decoder, this improve codec support and fix a few devices bugs, but can use a little more battery.
Offload mode
When using the device decoder, try to completely offload everything to the phone audio processor to reduce battery usage. On some device when combined with the Hi-Res settings this allows to bypass some phone sample rate limits.
Hi-Res support for local renderer
On devices that support it try to render the media at higher quality when the source is higher quality. (Will disable a few audio processorts like playback speed, skip silence, …)
Transcoding engine
Enable the internal transcoding ending to play a lot of new audio format like DSD, MPC, APE, …
Enhanced replay gain processor
Leverage the transcoding engine for replay gain (also when casting). Improves replay gain but uses more battery and requires some storage for temporary files.
