Notes:
Continuous playback
This have been replaced with Smart queue and Smart flow. Smart queue and Smart flow
Volume auto play / pause
Automatically pause the playback when you set your phone volume to 0.
Headphone auto play
Automatically resume playback when you plug your headphone.
Bluetooth auto play
Automatically resume playback when you connect your Bluetooth headphone. This requires an Android permission that you need to accept.
Pause playback on task removal
Enable to pause the playback when you remove the task from Android. Please note that some devices might trigger this at unwanted times.
Ignore remote stop commands
Some cars send a stop command when stopped. Without the multiple media queues option enabled this means that your queue is removed. Enable this option to ignore the stop command and consider it a pause.
