Notes:
Bluetooth lyrics
Enable to display synchronized lyrics on Bluetooth devices by updating the song title with the actual lyrics in real time.
Expert equalizer mode
Enable the option to activate more settings to the equalizer, like manual control of every band (up to 256) and more compressor / limiter options.
Equalizer block size
This setting impact the CPU usage and precision of the equalizer. Increase the value to improve precision and decrease the value is you have audio skip.
Reset AutoEQ database
Symfonium download the AutoEQ database to a local cache. This clear the cache and allows you to update the database.
