Settings --- Offline, Cache and Download
Notes:
  • Some settings may not be available on all Android version and some may only be visible when other related settings are enabled.
  • The application evolve frequently and in some cases the documentation can be late, just leave a message in the chat if you find an issue with the docs.
General
Cache storage location
If you have an external SD Card, you can select it here to store the offline media and the image cache there.
Automatic offline mode
When enabled Symfonium will automatically switch the available offline filter, effectively putting you in offline mode
Only consider primary connection for wifi status
Some VPN application, wireguard may cause issue with wifi status, disable this option to check alternative connections.
Media
Wifi only downloads
When enabled prevent offline file cache on mobile network. (This does not impact playback cache)
Offline cache and download quality
Configure the offline cache media quality (Transcoding)
Prefer server version on Wifi
If the device is connected to Wifi try to stream from the server and ignore the offline cache that can have lower quality.
Automatic offline cache of favorite
When enabled, when you favorite something it will be automatically offline cached.
Please note that removing the favorite status will not remove the files from the cache automatically!
Slower downloads
Some servers or proxy can have issues with Symfonium optimized offline cache system. Enable this option to reduce any potential issues.
Playback
Playback cache size
Configure the size of the playback cache. When enabled Symfonium will try to pre cache the current songs and the following queued songs to better support slow cellular network or network interruption.
The number of queued songs pre cache increase with the size of the cache.
Images
Persistent image cache
By default Symfonium cache the provider images in it’s cache folder to allow easy cleanup when required, or automatically by the OS when you run out of space. Unfortunately some “optimizer” tools clear this too often or some OS bugs can trigger the cleanup. If you rely a lot on offline mode then you can enable this option to ensure persistent image cache.
Wifi only image downloads
When enabled images not already cached will not be downloaded on mobile network.
High quality Images
Store the cached images in a lossless format, while this increase the quality a little, the space used is increased by a lot.
