Notes:
- Most settings are dynamic and depends on other settings values, some settings are also specific to landscape Expanded player.
- Not all settings will be fully described as most as self explanatory and easy to test via the preview.
Global
In landscape configuration you can directly copy the settings from the portrait configuration. That’s why it’s often better to start with portrait settings first.
You can press the preview button at any moment to see your changes. The preview is a little interactive, you can play/pause and change tracks to better see how it will look.
In landscape configuration you can configure the position of most global items.
Background
Background Style
Choose between different background styles for the expanded now playing.
Background Overlay
Choose between different overlays for the background of the expanded now playing.
Swipe up action
Configure swipe up action for the expanded now playing.
General
Switch top and bottom bar positions
Configure top and bottom bar positions for the expanded now playing.
Adaptive Primary Color
Configure background color for the expanded now playing.
Top bar
Style
Configure top bar style.
Background overlay
Configure background overlay for the top bar.
Top Bar margins
Configure space around the top bar.
Show collapse button
Toggle visible collapse button for top bar.
Collapse icon color
Configure color for the collapse icon in the top bar.
Title text
Configure info displayed as Title in top bar.
Subtitle text
Configure info displayed as Subtitle in top bar.
String Template
Configure string (text) to be displayed as Title or Subtitle text.
Text Color
Configure font color for Title & Subtitle texts
See Symfonium custom string template (v12+) for the documentation about Symfonium string templates.
Icon
Configure Icon(s) in the top bar.
Icon color
Configure color for icon(s) in the top bar.
Cover art
Cover Art Style
Configure the style for the cover (album) art.
Cover Art Margin(s)
Configure the space around the cover (album) art.
Cover Art Rounded Percent
Configure the roundness of the cover (album) art corners.
Rotation animation when playing
Configure rotation of cover (album) art during playback.
Do not crop cover art
Toggle to keep original cover art aspect ratio. (May remove / negate rounded corners)
Show play button when paused
Toggle visible play button overlay on cover (album) art in the Now Playing Screen (when playback is stopped).
Icon Overlay
Configure cover (album) art icon overlay (visibility).
Icon Size
Configure size of Icon overlay.
Icon Transparency when playing
Configure transparency level of overlay icons.
Horizontal Gesture
Configure the action when cover (album) art is horizontal swiped (left / right).
Tap Action
Configure action when cover (album) art is single tapped.
Double Tap Action
Configure action when cover (album) art is double tapped.
Long Press Action
Configure action when cover (album) art is long pressed.
Icons (Top / Bottom, Left / Right)
Configure overlay icons on the cover (album) art.
Controls and information
Row Order
Configure visible order of control & information elements.
Row Vertical alignment
Configure vertical alignment (spacing / position) of controls & information.
Controls Margin(s)
Configure the spacing around the controls & information elements.
Progress Bar
Progress Bar Style
Configure the style of the progress bar.
Progress bar style when no waveform data is available
Configure the default style of the progress bar when waveform is disabled or otherwise not available.
Progress bar margins
Configure the space around the progress bar.
Show position and duration
Configure if & when current or total track duration is displayed with the progress bar.
Show playback speed
Configure whether playback speed is visible.
Text Overlay
Configure over for text portions of the progress bar.
Text color
Configure color for the text portions of the progress bar.
Volume bar
Volume Bar Style
Configure the visibility style of the volume bar.
Volume bar margin(s)
Configure the space around the volume bar.
Icon Color
Configure the color of the icons in the volume bar.
Rating bar
Rating bar Style
Configure style of the rating bar.
Scale Factor
Fine tune the sizing of the rating bar.
Rating bar margin(s)
Configure the space around the rating bar.
Rating bar position
Configure the position of the rating bar within the Now playing screen.
Rating bar overlay
Configure overlay on rating bar.
Strings
String
Configure the text / info that appears in the compact player.
String Style
Configure text style / weight.
String Color
Configure text color.
String line count
Configure the number of lines of text visible.
String size multiplier
Configure text (font) size.
String margins
Configure spacing around the text.
String horizontal alignment
Configure horizontal alignment & spacing of text.
String overlay
Configure overlay of text.
String ellipsis
Select how Symfonium displays text that does not completely fit on screen.
Control button bar
Control button bar style
Configure the style of the playback & music control buttons.
Center in remaining space
Configure the spacing of the control button bar within the now playing screen.
Control button margin(s)
Configure the spacing around the control button bar.
Icon Horizontal Alignment
Configure the alignment of all icons in the control button bar.
Icon Spacing
Configure the spacing between icons in the control button bar.
Icons
Icon Action
Configure what happens when an icon is single pressed.
Icon Style
Configure the style of the icons in the control button bar.
Icon Size
Configure the sizing of the icons in the control button bar.
Bottom bar
Show in controls and information
Toggle whether the bottom bar shows within the controls and info on the Now playing screen.
Background overlay
Configure overlay for background of bottom bar.
Bottom bar margin(s)
Configure the spacing around the bottom bar.
Icon Horizontal alignment
Configure the alignment of all icons in the bottom bar.
Icons
Icon
Configure what happens when an icon in the bottom bar is single pressed.
Icon Color
Configure the color of icons in the bottom bar.
Lyrics and queue
In landscape mode you can have permanent lyrics and/or queue visible.
