Use this section of the application to manage offline files.
Press the desired section to navigate between them.
Offline files
This section list all the cached files and their size. While you can click on individual media to remove them, it’s usually easier to manage them from the normal library view with the available offline cache filter enabled.
The Cleanup button can be used to remove offline cached files that are no longer present on the server.
The Remove all button remove all the offline cached files.
Download queue
List all the files that will be downloaded, you can pause all the media, resume or clear the queue. (Beware that any automatic download rule will restart the downloads after next sync).
Auto offline rules
Symfonium support many different automatic download rules. (Artist, genre, library, …)
This screen allows to see them and easily remove them.
See: Offline media cache and downloads
