Notes:
Theme
Choose between different available themes. Including Material you on Android 12 and above.
By selecting Material You, Symfonium will automatically adapt to your system’s accent color, giving you a personalized experience that matches your system’s theme.
Primary color
Change the primary color of the application.
Import custom theme
Import custom themes to personalize the app’s appearance. These themes can change any color of the app, allowing you to fully customize Symfonium’s look to your liking. You can import themes in JSON format.
Typography
Select the fonts that will be used throughout the app. Choose from a variety of font styles to personalize your Symfonium experience.
Dynamic colors
When browsing the library, apply a primary color extracted from the main image.
