Notes:
Change language
On Android 13 and above open the OS app language selection to override Symfonium language.
Application logo
Customize the application icon by selecting a different image to be displayed in the device launcher and notifications.
Keep screen on
Choose when Symfonium should keep the screen on. (Always, when playing something, while showing lyrics)
Screen orientation
Lock the screen orientation.
Hide top filter button
Hide the filter button from the top button bar.
Hide cast button
Hide the filter button from the top button bar and the now playing screen.
Show changelog on updates
Show a changelog screen after application updates. Since the application evolve quickly it is recommended to keep the option on and read the changelog to avoid surprises when some default behavior may be changed and require you to toggle a setting.
