This isn’t necessarily an issue but an observation as I’m not sure this setting is working as expected.
I recently downloaded an album in a Radio / Clean Version as well as an explicit Version.
I Tagged the explicit version & then copied the tags over to the Clean version of the album, The only changes made were to the Explicit Tags & the album covers (the clean version does not have the infamous “Parental Advisory” badge
On my device I placed the two albums in different directories. In my provider settings I had Checked the following under Split Albums by:
Album Artist
Year
This unfortunately led to two albums instead of one combined album even though the Album artist & year tags are identical for both the clean & explicit versions of this album
Upload description: No Logs
For some context. I’m using the Global Filter or “Top Filter” button which simply allows the user to include / exclude various providers as well as Directories which is INCREDIBLY handy.
Often times I want to play songs in my library but the crowd I’m with requires a radio friendly version. In those scenarios I can enable one of my alternate directories & bam, I have the clean versions of songs at my disposal. After my outing I can go right back to my usual albums Immediately. All the alternates disappear until they are needed again.
After unchecking all the options under
“Split Albums by”
In symfonium both versions appear in one unified album & not two. My issue was solved but I had assumed even with the options I had selected before that a combined album would be the result.
Is a duplicate album expected behavior with Album Artist & Year selected in “Split Albums By”?
I can upload files if need be but again they are Twins with only changes to the Explicit Tags & embedded album Art. All Else is Exactly the same.
