Notes:
Use ASCII sort
Android sorts can either be case insensitive (A = a) or respect Unicode switch the option depending on your usage.
Ignore articles for sort names
When a provider does not provide sort names, remove know articles from the titles for the sort names.
Disable library auto sync
Disable automatic sync of the libraries. See Sync media provider data to do it manually
Remove empty albums, artists and genres
If after a sync an album, artist or genre have no associated media then remove it from the library.
