I have multiple devices which are running symfonium. But i want one device to stream flacs because it is always at home and then the other to stream opus. But in navidrome it sees all my symfonium devices as 1 player. Adding a way to set a custom player name can distinguish. Multiple devices from each other so you can set per device transcoding on navidrome side
To be able to set per device transcoding
Per device transcoding. So for when you have a home streamer which is flac then your phone on the go which will stream opus
