Last app I used had an option to allow screen to always stay on. This was useful for my old tablet I repurposed as a desk device to always play music and I can look at it to see whats playing or quickly change songs.
Thanks!
Thanks!
Will add a setting to keep screen on while playing.
Thank you so much! I tested it and works perfectly, plus a bonus over the last app I used was that if media finishes screen will now turn off while the last one did not.
Beware in next version you’ll need to configure the option again as it’s expanded to also support real always and not just on when playing.
